Hi !
Any idea to obtain something like this?
Thanks!
Admaiora
Solved by IgorMir. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
The closest will be a laser weld (bend tab in the flange dialog box)
Kacper Suchomski
Yeah. I was hoping in something closer.
Admaiora
Try this:
I do not know if it's gonna work. it occurred to me on the train, so I didn't check.
Kacper Suchomski
Hi Matteo,
While the model itself wouldn't look like the actually made item, if Three Bend Intersection Relief Shape is set to "Intersection" - the Flat Pattern will come out correct. And the manufactured item will look just like the one on the image of yours.
If, however - the model itself should look like the one on a picture - then there are some sort of workaround will be needed, most likely.
Cheers,
Igor,
Hi Igor!
Yeah, I have noted that issue.
Two bends the 3d preview is ok, 3 bends, not so ok.
Thank you for your care to point out that.
Yeah, the workaround it will be needed.
Thanks!
Admaiora
Hello Matteo,
If you really need a part, which looks just like the one on a picture and you want to get some sort of a flat pattern from it - the Unwrap feature can be of some help I think. Here is the part in IV2020 format,
Cheers,
Igor.
You can also edit the model directly in the flat pattern environment. There you can sketch and extrude a surface that will fill the gap.
Kacper Suchomski
