I am trying to make a detail of a sheet metal part with two views (unfolded & folded)....I know you can place a unfolded view by checking flat pattern in base view dialogue but that option is not available;le for some reason. If anyone knows what might be going wrong that would be greatly appreciated.
Have a great day.
Solved by Mark.Lancaster. Go to Solution.
You need to create the flat pattern in the sheet metal ipt first for that to be available..
I have tried that...i have been using the unfold command to make the flat pattern and it still only one base view option.
@Anonymous
The unfold command is used to unfold your sheet metal part, do something and then you refold. You need to generate flat pattern per these steps.
Mark Lancaster
& Autodesk Services MarketPlace Provider
