Inventor Forum
Sheet Metal Corners
5 REPLIES 5
chrisw01a
436 Views, 5 Replies
Sheet Metal Corners
When I create 3 sketches to make a corner come together, I get the desired result for a weld seam.
When I use the Flange feature, there is a gap.
Does anyone know how to change the parameters of the "gap" on the Flange feature?
Attached are two images as example.
Thank you.
Chris
5 REPLIES 5
in reply to: chrisw01a
Edit flange. Set miter gap.
Hi chrisw01a,
It looks like you might be new to the sheet metal tools. Here is a link that might be of interest:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-78F9188C-1B19-4DD2-9FC2-27B8A4B06E0D
Here's a quick video for the corner question:
I hope this helps.
Curtis
Got it.  Thank you guys.
CCarreiras
Hi!
You can do this in 3 places:
  1. In sheet metal rules: will apply for all cases during the modeling.
  2. In the tool: e.g. if you are using the flenge tool, despite you have an rule, for the present tool youre using you have a new rule for all the flanges yuo this time.
  3. In the corner: despite you have defined the sheet metal rules, or/and even the tool rule, you can change deffinitions directly in the corner.
So, basically you have usulally 3 levels of edition:
Global rules, apply to all the tools used, change every corner you make
The tool rule: apply to all the corners you are doing with that tool, change every corner this tool make
The corner specs: apply the specs directly in a specific corner.
CCarreiras
chrisw01a
in reply to: CCarreiras
Awsome! Thank you.
