- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Guys
Although I have worked with inventor for a very long time I have never used sheet metal so I really need some help here.
I attached my files so you can see how I went about achieving my desired design.
I took a normal IPT which was adaptive in another assembly and I got it to be the shape I want.
As it is a part for sheet metal work and I now need a flat pattern I decided to derive it into a sheet metal part and then sort of model over the derived part and in so doing if I change the original part my sheet metal part should also update.
Ok is this a good way to work with sheet metal parts which I think makes them sort of adaptive?
Secondly I have two images below. The first one is how I am currently getting my corner from the method I am using but I would like my corner to be the same as the second pic.
Thank you very much
