Inventor Forum
Sheet Metal : Corner Relief
2 REPLIES 2
chachaman
1035 Views, 2 Replies
Can somebody tell me why I cannot achieve the ARC WELD corner relief preparation I am seeking. I would like a more closed corner....please see attachments.
Thanks in advance !
2 REPLIES 2
This is a limitation.
You can only specify arc weld replacement in a "2 bend" corner. ie a flat sheet with 2 bend plates meeting in the corner.
3 bend corners has a much more limited replacement options.
You can see this in the active sheetmetal style corner tab.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
jhackney1972
in reply to: chachaman
The Bend Radius of your Contour Flange is giving you the corner.  If you change it to something close to zero, it will remove the corner gap.  Now the next question will be, can you fabricate it?  The screen capture below, the contour flange bend radius is set to .005".  Likewise, if the Flange bend radius was also reduced, it will close up even more, again, will you be able to fabricate it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
