Inventor Forum
Sheet Metal cone development error?
5 REPLIES 5
952 Views, 5 Replies
When I create a cone the developement is fine ( a triangular(ish) blank).
If a small swage is added to the top of the cone & 'Contor Roll' applied - the whole blank becomes rectangular!
Is an addin available to cope with swages?
MES
5 REPLIES 5
CCarreiras
Hi!
Can you attach the part?
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
pls find example attached.
MES
CCarreiras
Hi!
In real world, this last operation consist is a plastic deformation, so, by deffinition it will occur a variation in the thickness, it's not a bend, so the inventor can´t calculate the flat pattern.
CCarreiras
Thanks for the feedback.
Is there any software or Inventor add-in which will cope with swages being added to sheet metal parts?
MES
mrattray
Carlos is correct. This is sometimes referred to as a double curved surface. SPI SheetMetal is an Inventor add-in that will unfold parts like this. It's from a German company so don't be too surprised when you see a website full of Deutch.
When I was looking into I spoke to: Danny Picheta <dp@spi.de>
There is other software that will unfold these parts, but I'm not aware of another one that is an add-in to Inventor.
Do some Googling.
Mike (not Matt) Rattray
