Sheetmetal is never exact, because it depends on material and bending process. Inventor uses approximations.
In your case, this can be influenced by:
- Rounded values in the flat pattern
- Position of the bend line
- K-factor
A close look at your file shows, that the bend extends into small regions of the short leg. Even my optimized geometry shows it, but that can't be done in reality.
I re-positioned the bend line, and changed the K-factor. Now it's better.
Remark: The used K-factor for the flat pattern should always be written to the drawing
2016 IPT attached
Walter Holzwarth
