@Anonymous
Well, I hope you are still around since I just spent a couple of hours working up this example. 2016 example attached.
It is almost always better to pattern a body rather than features (in this case my first body "pattern" is Mirror).
(This principle is true both in SolidWorks and Inventor.)
Drag the End red End of Folded marker to just below Sketch2 and then down step-by-step (this is equivalent of feature roll up bar in SolidWorks).
For the Louvre I used 3 different pattern techniques to demonstrate.
1. First pattern is of the Features.
2. Second pattern is of Sketch Points used to place Punch tool. In some cases this is the best way to place Punches and is so easy that I use it for non-sheet metal parts too.
3. Third pattern is how I would normally do a Punch pattern in SolidWorks or Inventor (except of course I would do all three rows rather than just one).
I realized that I did make one mistake - but I need to move on to other work. This example should give you some ideas.
