sheet metal assembly
Message 1 of 27
can anyone help me out,  im struggling with this assembly
I have a tile and then a led channel, I need the led channel to sit on the 60mm deep angled side
with the 20mm bottom fold being on the underside off the face of the tile
thanks in advance
Replies (26)
Message 2 of 27
TheCADWhisperer
Have you installed all Service Packs and Updates for your version of Inventor?
I would not use Fold - I measured the end results and I will make a wager they are not what you intended.
No assembly file attached?
Message 3 of 27
Thomas_Savage
Do you mean like the print screen I attached?
Thomas
Thomas Savage
Design Engineer
Message 4 of 27
assembly attached
i had a flat blank and created folds just for this excercise
i already know everything works,just need to do an assembly
Message 5 of 27
theangle needs to be the other way up
Message 6 of 27
Thomas_Savage
Like the print screens attached?
Thomas Savage
Design Engineer
Message 7 of 27
Capture.PNGas picture attached
really struggling with this
Message 8 of 27
sorry my picture, the angle needs to be the other way up
Message 9 of 27
yes thats correct, how do i do that please
Message 10 of 27
thats it
Message 11 of 27
TheCADWhisperer
Can you use the Free Move and Free Rotate as needed to line up the parts as close as you can get by eyeball and then attach that assembly (*.iam) file here?
Message 12 of 27
Thomas_Savage
Select constrain, and then just select the 2 faces that you want to place together.
Do it on the 2 faces that you can see from my print screen, that are together.
Thomas
Thomas Savage
Design Engineer
Message 13 of 27
Thomas_Savage
I have attached constraining the first face.
I selected the 2 faces that you can see that are coloured. Then just select ok.
Then they will be constrained. And just do the same with the top, and inside of the other 2 faces to constrain the top.
Hope this helps.
Thomas
Thomas Savage
Design Engineer
Message 14 of 27
Message 15 of 27
Thomas_Savage
On the idl tile select the side, not the top flange. Like in this print screen.
Then it will constrain to the side.
Thomas Savage
Design Engineer
Message 16 of 27
Capture.PNGthen it does this
Message 17 of 27
Thomas_Savage
Yes that's how it should go.
Select ok.
Then pick the 2 faces I have attached. The faces with the arrows pointing to.
Then it will line it up.
Thomas
Thomas Savage
Design Engineer
Message 18 of 27
thomas
so simple, but its just not working for me.
thanks for your help though
if you get time, do you think you could do a video?
thanks
Message 19 of 27
Thomas_Savage
You could have mates that you have placed that is over constraining and stopping you.
Start a new assembly, and do 2 constraints. The first one you did. And then the one I just shown you.
See if that works.
I will try do a video.
Thomas Savage
Design Engineer
Message 20 of 27
i think ive cracked it, i had 2 do 3 constraints though
ill attach assembly tomorrow as its not letting me attach files
