Here I share a library file to place wooden beams with gl24h material, you have to copy it to C:\ProgramData\Autodesk\Inventor 2024\Content Center\Libraries
Only valid for inventor 2024 a like for the time, greetings
This sounds interesting! Unfortunately I only have 2022 and 2023. I tried with 2022 but it didn't show up in the Frame Generator. Will try with 2023 next week (you never know! 😄)
A while ago I did some experimenting with wood beams in the FG, using the standard 120x120 mm solid square steel that I simple changed the appearance of. At a glance it looked ok, but fixing all the joints manually was a pain.
Tried with IV 2023 now, unfortunately no success.
aqui comparto el archivo de vigas de madera para inventor 2023 ..un me gusta por el tiempo dedicado ..
