Inventor Forum
Share Sketch
6 REPLIES 6
1505 Views, 6 Replies
Share Sketch
You can see in some drop down menu there is share sketch option and in some drop down menu there is no share sketch option. What is the reason for that.
6 REPLIES 6
CCarreiras
Sometimes it can happen.
If you need to use it in another feature, just turn it visible and you can use it again.
CCarreiras
JDMather
Uhmmm, perhaps because it is already marked as a Shared Sketch (that is what the hand in the sketch symbol means).
Sketch3 is shared in Extrusion7, 3, 4.
mdavis22569
in reply to: CCarreiras
look at the 2 icons also
you have a sketch ...and it's letting you share it
and in the 2nd icon you've highlighted an already shared sketch ...sketch shared.PNG
Mike Davis
in reply to: JDMather
My understanding from your explanation is all sketch drop down menu has share sketch option. If we use that option then there will no longer be a share sketch option in that drop down menu of that particular sketch.
mdavis22569
no ... you can continue to share the original sketch ..
you can't share a shared ...   that's why you don't see it that drop down.
Mike Davis
CCarreiras
in reply to: mdavis22569
This is a known issue (one of the several present in the browser in all of enviroments).
There's no logical reason, It's kind of a harmless bug.
Workaround: Make it visible and everyone can use it as a shared sketch.
CCarreiras
