Shape generator Analysis fail (2021)
admaiora
Mentor Mentor
Message 1 of 22
admaiora
Can you help me to understand why it fails?
The file was created in previous versions, than migrated.
I presume that if i remodel it from scratch I would have no problms..
attached the file
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Replies (21)
Message 2 of 22
admaiora
Actually it fails from scratch too.
And with most of other fails that worked in the past.
Am I missing something?
Do you have the same issue?
Admaiora
Message 3 of 22
johnsonshiue
Hi Matteo,
I am not seeing the defective behavior on 2021. When I opened the file on my machine, Inventor prompted me for the .fin file (FEA result). I just skipped it. I am able to run the ShapeGen without a problem. I suspect .fin might be corrupted. You may want to delete the .fin file.
Many thanks!
Software Test Engineer
Message 4 of 22
admaiora
Hi @johnsonshiue
Thanks for the feedback,
so the problem is on my side. I see that it's not related to the file, here I do a study from scratch.
Any idea how I can fix it?
Admaiora
Message 5 of 22
admaiora
I really don't understand.
Same file, same settings, all updates done.
2017, no problems
With 2020, no results:
With 2021 no reults:
With 2020 and 2021 I can realize successful analysis, but no clue why , randomly it fails.
Attached the file
many thanks!
Admaiora
Message 6 of 22
johnsonshiue
Hi Matteo,
Is it possible you have Inventor NASTRAN installed? If you disable the Add-In, does it work on 2020 and 2021?
Many thanks!
Message 7 of 22
admaiora
Brilliant @johnsonshiue !
Indeed I have Nastran in CAD installed in 2020 and 2021.
We are getting closer.
After unload Nastran in CAd in 2020 and 2021:
-2020 Shape Generator it 's working again fully, no problems. Works greats with every file.
-2021 still no results (same files), even if Nastran i s unloaded.
Admaiora
Message 8 of 22
ChrisMitchell01
Does NASTRAN itself work? Can you create a quick study, mesh & solve it in both 2020 & 2021?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 9 of 22
admaiora
@ChrisMitchell01 @johnsonshiue
Hi Chris,
here a global summary:
With Inventor 2020  (Build 373, Release 2020.3):
-Inventor Static Stress analysis >> Completed, no problem (mesh and results)
-Inventor Shape Generator analysis >> Completed, no problem (mesh and results)
-Nastran in CAD Static Linear analysis >> Completed. no problem (mesh and results)
With Inventor 2021  (Build 183, Release 2021):
-Inventor Shape Generator analysis >> ISSUE (mesh completed but NO RESULTS)
-Nastran in CAD Static Linear analysis >> Completed, no problem (mesh and results)
Attached the file (but the same for all the files)
Here the videos of the tests for 2020 and 2021:
Thanks!!!
Admaiora
Message 10 of 22
ChrisMitchell01
Thanks for these - this shows that it's not a licensing issue as I was assuming it might be...
Does it work if you ustart Inventor using Run as Administrator ?
Any log files of use in %temp% ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 11 of 22
admaiora
Hi @ChrisMitchell01
Does it work if you ustart Inventor using Run as Administrator ?  >> No.
Any log files of use in %temp% ? >> You will find it attached
Many thanks!
Admaiora
Message 12 of 22
uw
Hi.
Is there a solution to this problem in the meantime?
I have absolutely the same problem in Inventor 2020.3.4.
The shape generator stops after a few seconds of calculation without any result...
Best regards
 Reinhard
Message 13 of 22
johnsonshiue
Hi Reinhard,
Do you have Inventor NASTRAN installed?
Many thanks!
Message 14 of 22
uw
Yes I have the latest version of Inventor NASTRAN installed!
Kind regards
 Reinhard
Message 15 of 22
damian.lewczyk
Autodesk Support
Autodesk Support
Hi.
I have a customer who has a similar problem.
@uw do you have some AntiVirus software installed on your computer? What is the name of AV
What is the name of your company?
Damian Lewczyk
Technical Support Specialist
Message 16 of 22
uw
I didn't install anything other than Windows Defender, the standard-AntiVirus software in Windows 10.
I do not work for a company, I am a teacher at a school (Higher technical college) in Austria!
Kind regards
 Reinhard
Message 17 of 22
damian.lewczyk
Autodesk Support
Autodesk Support
Please follow the steps.
  1. Download RegistryFEACS.zip which I attached to this message.
  2. Unzip and run RegistryFEACS.reg (this will create in your registry following folders \HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Simulation\RegistryFEACS)
  3. Run the Shape Generator.
  4. When the calculation is finished go to:  c:\Users\<user_account_name>\AppData\Local\Temp\<a single number>
  5. In this folder (in my computer is "1") you should find the following files: FEAComputeServer*.log.
  6. Please send this file to us.
  7. After you get this file delete the Simulation folder from \HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\ in your registry (to run registry type "REGEDIT" in windows search)
Damian Lewczyk
Message 18 of 22
uw
Hi.
As I said, I had problems with version 2020.3.4.
A few days ago I have updated to version 2021, and I haven't had any problems so far...
To be honest, I don't want to make changes to my registry.
I would get back to you if the problem occurs again!
Nevertheless many thanks
 Reinhard
Message 19 of 22
chris.cremeens
Message 20 of 22
admaiora
Any fix? Or idea?
Admaiora
