Inventor Forum
shaded problem in IDW drawing
13 REPLIES 13
Message 2 of 14
643 Views, 13 Replies
every time i shade a figure in a IDW file there are shadows and the colors are affected. if anyone can kindly help me with that.
kelly.young has embedded your image for clarity
13 REPLIES 13
Message 1 of 14
clutsa
This would better fit in the forums section then the ideas section. Please re-ask your question there.
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Message 3 of 14
Xun.Zhang
Hi @Anonymous,
Which version are you using? Is there any specific setting in your drawing template? if so, could you attached a sample data with the template here?
thanks!
Xun
Message 4 of 14
johnsonshiue
Hi! I could be wrong but the issue looks graphics related. To rule out graphics hardware issues, please update graphics card driver first. Go to your graphics card vendor website and find the latest compatible driver. Also, change hardware option to Conservative (or Compatibility mode). Start Inventor and go to Tools -> Application Options -> Hardware -> Conservative mode. After that, does it work better?
Many thanks!
Software Test Engineer
Message 5 of 14
in reply to: Xun.Zhang
hello. I'm using autodesk inventor professional 2017. and no i have no specific settings. also this problem is not with the graphic because sometimes is clear and sometimes no. also when i zoom into the image is clears itself but when i zoom out, back to being shaded weirdly.
Message 6 of 14
johnsonshiue
Hi! Based on your description, it does sound more like graphics related. Please share your hardware profile with us. Start Inventor and open a file. Go to Tools -> Application Options -> Hardware -> Diagnosis -> paste it to Notepad and save it as text file. Send it directly to me (johnson.shiue@autodesk.com).
Many thanks!
Message 7 of 14
Xun.Zhang
Hi @Anonymous,
Please share your data to me (xun.zhang@autodesk.com), it's really difficult to figure out the reason without the data.
Thanks!
Xun
Message 8 of 14
in reply to: johnsonshiue
Hi all
I just have exactly same problem tried everything with no luck.
I'm using Inventor 2018.
Last week all was good, some reason this week is just something gone wrong, all the IDW is Shaded.
I tried updating the graphics but still same.
Please help.
Message 9 of 14
mcgyvr
@Anonymous wrote:
Hi all
Please help.
@Anonymous What graphics card? What driver version are you using? What is your operating system?
If you go to tools..application options..hardware tab and check software graphics check box THEN RESTART Inventor.. Does the problem go away?
Message 10 of 14
in reply to: mcgyvr
Message 11 of 14
mcgyvr
@Anonymous wrote:
@Anonymous Your day is not saved yet..
All that does is indicates the problem is with the current graphics card/driver you are using..
Software graphics WILL typically cause a decrease in performance and is really only intended as a diagnostic tool..
Now you need to find the proper driver or update your graphics card to one that is suitable for Inventor unless you are ok with decreased graphics performance..
Please let us know the graphics card/driver you are currently using if you want help/suggestions there..
In general I've always just used the latest driver from the card manufacturers site and had no problems.. But I always have a good/fairly up to date,etc... graphics card in my machines an not just use the one that comes on the motherboard or a cheap one really intended for just normal office computers..
Message 12 of 14
in reply to: mcgyvr
Hi
Please see attached Pictures.
Thank
Message 13 of 14
mcgyvr
@Anonymous
Your driver is out of date..
Try this..
Version 391.01 - WHQL
Release Date Mon Feb 26, 2018
Operating System Windows 10 64-bit
Language English (US)
File Size
433.57 MB
Message 14 of 14
in reply to: mcgyvr
ok I try it.
Thanks so much.
