Message 1 of 16
I have a sugar storage tank and need to perform FEA simulation.
At this time I only performed creating mesh view.
However it took more than a day and the simulation seems not going to the end.
Your help(s) are much appreciated.
The screenshot (below) shows the mesh setting.
Please note:
1. For simplifying the analysis all life loads are not considered.
2. Fixed constraints on foot (4 off)
Here is the tank details (simplified model)
Capacity: 60,000Kg (Sugar)
Tanks Size (approx.): Ø4000mm x 10000mm (height)
Tank wall thickness: 4mm (typical)
Footing: 20mm Thick (typical)
Material: Stainless Steel 304
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
