Settings for FEA Simulation
BeKirra
Advisor Advisor
Message 1 of 16
BeKirra
I have a sugar storage tank and need to perform FEA simulation.
At this time I only performed creating mesh view.
However it took more than a day and the simulation seems not going to the end.
Your help(s) are much appreciated.
The screenshot (below) shows the mesh setting.
Please note:
1. For simplifying the analysis all life loads are not considered.
2. Fixed constraints on foot (4 off)
Here is the tank details (simplified model)
Capacity: 60,000Kg (Sugar)
Tanks Size (approx.): Ø4000mm x 10000mm (height)
Tank wall thickness: 4mm (typical)
Footing: 20mm Thick (typical)
Material: Stainless Steel 304
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Replies (15)
Message 2 of 16
JDMather
Attach your file(s) here.
You have an extreme aspect ratio - you should be using Thin Feature shell elements.
Sugar would exert forces more like liquid - you will need to use a hybrid technique that resembles hydrostatic forces in Inventor (or use Nastran).
Message 3 of 16
BeKirra
Thanks for your reply.
Please find the file.
Note: I use 2019 version.
X² + Y² = C²
Message 4 of 16
JDMather
Go through this first - then post back if you still have questions...
Message 5 of 16
johnsonshiue
Hi! Another approach to consider is to create a part simulating the sugar (dead weight). You can compare the results to see which one is more realistic.
Many thanks!
Software Test Engineer
Message 6 of 16
BeKirra
Thanks to @JDMather I will have a look your video.
And also thanks to @johnsonshiue Do you mean to create a sugar solid in the model?
X² + Y² = C²
Message 7 of 16
johnsonshiue
Hi! Yes, I think you could simulate the sugar as a solid body. It may not be accurate but no FEA can depict precise deformation. It is just how close the result will be.
Many thanks!
Message 8 of 16
JDMather
I don't think that would work.
How would this body impart load onto the tank?
Only force would be load due to gravity.
I still think my hybrid technique (if staying in Inventor) of treating the sugar as sort of a fluid exerting graduated pressure on the sides of the tank as well as the bottom is the way to go.
Only for calculations to convert load to pressure I would model the sugar as a solid body gradually increasing height in reverse from top to bottom getting weight to convert to pressure (will require some hand calcs, at least for the bottom).  Sugar would have more friction than fluid so pressure on sides of tank would be a bit less than the calculation, but as you said this would be an approximation anyhow.
See anything wrong with my thinking?
@BeKirra
Have you made any progress?
Message 9 of 16
BeKirra
Thanks @JDMather your video helps a lot. I am still working on my model and am learning from your tips.
Another questions here.
1. How to take the weight of tank to the FEA when it is big enough?
2. If it is the case, will you insert "force" or "pressure" to the feet?
Thanks.
X² + Y² = C²
Message 10 of 16
JDMather
1. The weight of the tank (not including sugar) is based on the material and Gravity.
2. Fixed constraints bottom of the feet and turn on Gravity.  Inventor will figure out the rest.
Message 11 of 16
swalton
Over the last 18 months or so, I've had to learn much more than I wanted to about bulk material bins and hoppers.
You might find these references useful to guide the loading of the FEA.
https://www.aiche.org/sites/default/files/cep/20131125_1.pdf
https://www.qualicer.org/recopilatorio/ponencias/pdfs/0013041e.pdf
https://www.hindawi.com/journals/ace/2018/3673515/
https://news.bulk-online.com/bulk-solids-handling-archive/bulk-materials-storage-design-consideratio...
Steve Walton
Inventor 2025
Vault Professional 2025
Message 12 of 16
BeKirra
Thanks @JDMather
How to place gravity to a model? I take your video as an example.
It seems Inventor only allows to place gravity on a single point.
How to place it to a 4 foot tank? Or did I miss something?
And also thanks to @swalton I will take some time to read through the articles.
X² + Y² = C²
Message 13 of 16
JDMather
Gravity effect the entire environment - you only need to set the direction.
Click the bottom face of the tank to set Gravity perpendicular to the face or select any vertical edge to set the direction.
If  you have not applied Gravity before - I assume that you are a beginner with FEA.
I urge you to use extreme caution in interpreting the results in any analysis you run.
Message 14 of 16
BeKirra
Yes, I am not familiar with FEA.
How to place gravity to the model that is shown on my 1st post?
on the bottom cone?
Thanks.
X² + Y² = C²
Message 15 of 16
JDMather
Gravity is everywhere - ignore the location of the arrow glyph, only the direction of the arrow is important.
You could select the bottom of the cone or the bottom of a foot or any vertical edge of a foot, or....
If you would like the arrow in the center for aesthetic purposes, simply expand the dialog box and select Use Vector Components.
Message 16 of 16
BeKirra
Thanks again. @JDMather  👍
BTW I misplaced a post in other forum.
https://forums.autodesk.com/t5/simulation-mechanical-forum/fea-files/td-p/10478122
Can you please take a look? The question is about securing FEA files.
Thanks.
X² + Y² = C²
