Inventor Forum
Setting "Edit Member Scope" as default setting
1 REPLY 1
388 Views, 1 Reply
I have seen the other post on this topic.  But I do need to set the default to "Edit Member" we work in specials and rearly need to edit the factory scope.
Is there a way to set the default to "Member only" on ipart tables?  Maybe with iLogic on start up?
1 REPLY 1
mcgyvr
I am not aware of anything (though there maybe a registry setting or something)..
Do you not edit iparts via the table?
Personally I use iparts/iassemblies and rarely if ever do I need to use "edit member".. I always just work through the ipart/iassy table to modify the members an as such you don't need to set that.
Technology Administrators
