Setting Drawing Dimension as Parameter Name
rkurthQU849
rkurthQU849
I have created an iPart where the length and the hole locations change depending on the part selected.  In the .DWG I placed a table to show each iPart option but when I dimension the view I do not see an option to put the parameter name instead of the base view value.   I know that I can use the 'hide dimension value' button and type in the name I want but I would rather have it linked to the actual parameter name in case the parameter name changes it automatically updates the name in the dimension.
Is there a way to put the parameter name as the dimension value without using hide?
Thank you.
johnsonshiue
Hi! Unfortunately, I don't see a manual workflow to do that. Maybe, there could be a solution using iLogic.
Many thanks!
Software Test Engineer
rkurthQU849
Thank you.  I will have to look into writing an iLogic script.
Good evening did you succeed with ilogic to make the parameter mome out in the drawing dimension to be able to create a master idw with table?
Jallen_USBattery
@Anonymous  @johnsonshiue
I am actually trying to do the same thing but on a larger scale so I can just show the parameter name (or even just a bubble #/letter would suffice)
Doesn't help that I am brand new to Inventor Drawings... thing should be fun! 😃
I am also struggling bc the multi-bodied iPart doesn't seem to be able to split into 4 separate components that I can make individual drawings of, so I resorted to 'Cropping' each view and moving the crop sketch around to generate drawings for each of the A/B/C/D combs. Is there a better way I can do this?
Can someone point me in the right direction for this iLogic bit?
johnsonshiue
Hi! I am not an iLogic expert. Here is a related topic with some helpful code.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/user-parameter-how-to-retrieve-dimen...
Many thanks!
Jallen_USBattery
Well that makes 2 of us, I have not yet delved down the iLogic rabbit hole. I would love to soon but for now I have to get this done just using the "hide parameter" tick box when editing the dimension.
I will mark this down for a future study to implement. I appreciate your help though!
