- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created an iPart where the length and the hole locations change depending on the part selected. In the .DWG I placed a table to show each iPart option but when I dimension the view I do not see an option to put the parameter name instead of the base view value. I know that I can use the 'hide dimension value' button and type in the name I want but I would rather have it linked to the actual parameter name in case the parameter name changes it automatically updates the name in the dimension.
Is there a way to put the parameter name as the dimension value without using hide?
Thank you.
