Set View Label Defaults
ballnr
Message 1 of 9
ballnr
Hi all,
Normally I set "View Label Defaults" for detail view same this picture
You can see the resault in picture.
If I need the resault same this picture
Is it possuble to set?
Please suggest.
Replies (8)
Message 2 of 9
3D4Play
I think you can accomplish it here:
Message 3 of 9
ballnr
I already try
The resault.
Please help and suggest.
Message 4 of 9
3D4Play
Try putting a space after your Label Prefix text. 😉
Message 5 of 9
BeKirra
@ballnr wrote:
I already try
Here is another workaround.
You will be able to see what you want to display.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 6 of 9
ballnr
Thanks for suggest.
When I try to set.
The resault differance
Please help
Message 7 of 9
BeKirra
Ok, in the display box, the text will be remained as the same before:
"<VIEW IDENTIFIER>" (<SCALE>)
Then type the following in Label Prefix box:
Detail
Note: remember to add an extra space after the text "Detail".
X² + Y² = C²
Message 8 of 9
ballnr
Is it the same massege No.6
Message 9 of 9
BeKirra
@ballnr wrote:
Please help
Ok, please remove the "Detail" in Label Prefix box shown above.
Then right click your detail view.
Add Detail in the Label box (see below).
HTH
X² + Y² = C²
