Set dimension extension line type to center
amkuhnKVHH9
amkuhnKVHH9
My group cannot find how to change the extension line type to Center without also changing the dimension line.
Is there a way to set only the extension line type? This is a standard property in AutoCAD
ampster40
Look inside the Styles Editor.  You should find what you are looking for.
ampster40
peeking inside the styles editor, I do not see where Autodesk created a property specifically for extension lines.  Only Dimension lines.
This isn't AutoCAD obviously.
Not sure how you will be able to do this without some under the hood coding.
