I've designed something, but unfortunately, all the parts of the design ended up in a single "body". Coming from SW and Fusion, this is a bit confusing, as this feature ("disjoint lumps") is new to me, and I'm confused as to how to separate the part into multiple solid bodies when there's no clear way to cut it using eg. the split tool. Is this possible?
Is there a single feature to do this or even a workflow? I need the parts to be in separate bodies so that I can assemble it and eventually 3d print it.
I've attached the file I'm having problems with.
Solved by johnsonshiue. Go to Solution.
Thanks for the reply however this doesn't solve the problem--It breaks the file and if I attempt to accept it regardless, it still only leaves me with two bodies instead of 14 separate bodies
@124475Tilman wrote:
Coming from SW and Fusion, this is a bit confusing..
I didn’t look at your file, but the correct technique is to do it Exactly the same as in SolidWorks and Fusion 360. New Body or New Component when creating.
The difference is that Inventor also permits Disjointed Lump bodies (that can be advantageous) if you don’t take explicit control.
You might be able to Edit Feature and take this control if you haven’t created dependencies that would cause to fail, or you might be able to Split what you have (same as in SolidWorks and Fusion 360). I am not at my Inventor machine to check your file at the moment, but I will check later if Edit Feature as suggested by @89198826955 or Split does not work for you.
I've tried again, and instead of extruding multiple keys at a time, I extruded one and then patterned it as @89198826955 recommended. Unfortunately, once they are separate bodies, I can no longer reliably feature-pattern on them--when the extrusion is *subtractive*, it lets me select multiple bodies and pattern the holes, but when the extrusion feature is *additive* the gui does not let me select multiple bodies to be considered, and all the circular pattern copies end up in the original body:
I've attached my latest attempt
what is your solution?
fast or good?
Fast: Suppress array element Right mouse button, select "suppress"
another solution:
designing one button with one body
designing another button with a second body
then we make an array of bodies
Thanks for the replies, but none of these methods are really satisfactory when compared in efficiency to eg Fusion 360's method of operation. The challenge in this particular exercise is that there is collection of slight variations of a patterned element, and Inventor is apparently unable to deal with this. Specifically, most of my problems could be solved if it were possible to extrude pattern elements that automatically join bodies that they intersect, rather than either forming new bodies or staying in the original (disjoint) body.
Hi! Indeed, Fusion considers separate solids as different bodies. In your case, you start with a sketch with disjoint profiles. Th result is a solid body with disjoint lumps. All the following features are added to the same solid bodies.
Inventor does support multi-solid body workflow and also separate disjoint lumps.
In your case, if you start all over, you will have to extrude the profile one at a time (New Solid option) to create the individual solid body.
It is indeed unintuitive to separate disjoint lumps into solid bodies. There is a workflow to help. Once you are done with disjoint lumps and you want to separate them into solid bodies, you may count how many lumps you have. Let's say it is 'n.'
1) Create a rectangular pattern of the body -> Create New Body -> set number of occurrences = n and distance to 0. You will have solid bodies overlapped one another.
2) Go to Solid Bodies folder -> right-click on each solid body -> Hide Others.
3) Delete Face -> Lump selection -> pick the unwanted lumps in the solid body. Repeat step 2 and step 3.
Many thanks!
This is exactly what I needed! Thanks!
Still a shame that such a un-intuitive process is required for such a (in my mind) simple operation. Clearly the software can already identify the different solids that compose the disjoint lumps (in the delete face feature) so it should be trivial to have a "Explode Solid Bodies" feature which--like the delete face feature--lets users select parts of disjoint-lump solids and separate them into new bodies (basically the reverse of the "Combine" Function).
Is there a place where I could request this feature?
Inventor Ideas forum is exactly what you are looking for. You can search there to see if such an idea already exists and lend it your support, or create a new proposal. Either way, come back to this topic and share a link so others can add their votes.
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
