Self-intersecting loop
Message 1 of 14
I have fixed the problem but I usually get this type of error window. I couldn’t understand the meaning of this. What does this mean?
Accepted solutions (3)
Replies (13)
Message 2 of 14
mdavis22569
Use the sketch doctor fully click next or diagnose ... zoom in on your connection points (where the lines come together to each other.) One is overlapping more than likely
attach the part  ...
Mike Davis
Message 3 of 14
Could you please explain this in detail?
After seeing green dot only point is selected how can it be go wrong?
Message 4 of 14
mdavis22569
Can  you share the part
overlapping ...the lines don't come together and meet 100% they cross and "overlap"
Something like this ..
Mike Davis
Message 5 of 14
So that green dot is not certain when defining a point.
Message 6 of 14
Mark.Lancaster
@Anonymous
Without seeing your information or how you did you sketch we can only speculate where the overlapping geometry is.
For example (and I only did this to show an example of an overlapping sketch) here's what Mike is referring to...
I'm thinking when you did the arc it wasn't tangent to the line or you didn't apply a tangent constrain.   At certain zoom level it may look okay to the naked eye but if you could really really zoom in you will most likely fine the arc overlapped the vertical line.  But we can only speculate at this point..
Mark Lancaster
Message 7 of 14
mdavis22569
@Mark.Lancaster  we think and draw alike too ...lol
Mike Davis
Message 8 of 14
Mark.Lancaster
@Anonymous
I looked at your sketch..  Not sure why you placed that other point..  But I deleted your arc, put it back in and applied a tangent constraint between the arc and vertical line.  No problem and no overlapping information.
Mark Lancaster
Message 9 of 14
It is not said in demo that arc is tangent to the vertical line. I wish to whether it correct to assume it.
Message 10 of 14
JDMather
What video?
Does the sketch make logical sense as you have drawn it?
Did the video instruct you to add the extra sketch point?
What manufacturing process is used to create an arc to .001mm tolerance?
Q. How thick is a standard sheet of paper?
Message 11 of 14
This is a video from YouTube. Just I want to replicate the work.
https://www.youtube.com/watch?v=eGCRbSfV89Y
Message 12 of 14
This point in the sketch was spontaneously added when I used sketch doctor to fix the problem. Could you please explain the reason?
Message 13 of 14
JDMather
The youtube presenter clearly only has a partial understanding of geometry.
The presenter selects center point arc tool and then carefully tracks over from the end of the arc - this implies tangency.
But Inventor did not automatically add the tangent constraint and then the presenter overrode by adding unnecessary dimension and trimmed without connecting the endpoint at other end (note that the sketch is still unconstrained).
Only two dimensions and a tangency are needed.
I would eliminate the 1.651 dimension as it is fantasy anyhow.
Only the radius and the 6.35 and tangent are needed.  The 1.651 will be solved by the geometry conditions. It is what it is.
Logic must be a part of the design process.
The presenter started out creating the arc using a logical process but then got lost when the endpoint did not match a rounded off calculation distance.  Use geometry.
Q2. What is 1.701-1.651=?  State answer in terms of ratio of the thickness of a sheet of paper.
BTW - when you cite a source of information - you should reference the timestep so that it is easy to find.
Message 14 of 14
