Selecting region
Selecting region
This is a video. In order to do a loft command I have to select region B, but cannot select. I was able to select opposite site region A. What is the reason?
https://www.youtube.com/watch?v=CpQnFYJyEn0
Time around 3:22
Accepted solutions (3)
Replies (13)
mdavis22569
you have to place with the right Shift to remove the area ....
but i got it to work
Mike Davis
Could you please explain what is meant by right Shift?
mdavis22569
updated
Mike Davis
mdavis22569
shift button to remove that area
Mike Davis
CCarreiras
Obviously... a bad sketch..
the <v is not conected to the top line.
If you make a good sketch, the problem vanish...
CCarreiras
I know Shift key I do not know shift button. Before I used Ctrl key to select the region I want, but it did not work.
mdavis22569
same things ...sorry ..shift key
Mike Davis
the <v is not connected to the top line.
Before using LOFT command I used Extruder command to establish the region is closed. Beyond this how to establish the sketch is good?
admaiora
Effectively the selection can be sometime a little tricky.
With tricky sketches sometime you can help a little the sketch
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
CCarreiras
If theres a problem with selecting profiles,  it's because the sketch isn't robust.
The video... is not a good exemple, to much dimensions, sketch not very well constructed (almost a crap sketch). It's better somethimes just a couple of dimensions and the rest constrained with geometric constrains, and .... a important factor is.... every geometry that you will not use as a profile, turn it in work geometry... and most of this problems will go away...
Try to delete the top line, and do it again...
CCarreiras
I wish to know whether it is possible to do this without having project geometry.
CCarreiras
No.
Project geometry to constrain geometry you need to profile, and turn all the geometry you dont need to profile in work geometry.
All fully constrains the sketches, doesnt matter if are center lines or others....
Thids is the way to work correctly... as a pro.
CCarreiras
