Inventor Forum
Selecting closed loop
4 REPLIES 4
admaiora
695 Views, 4 Replies
Those are all closed individual rectangles.
Why there is this behavior?
It's quite impossibile to select the wanted area.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
4 REPLIES 4
johnsonshiue
in reply to: admaiora
Hi! Inventor profile recognition is not able to detect a region if there isn't a coincident constraint at the intersection between two crossing lines. Try adding coincident constraints at the intersections. The profiles should be recognized. If it still does not work, please share the file or send it to me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
salariua
I had that from time to time, especially with AutoCAD imports and usually, I make them all construction and turn them back on as needed.
Screencast server is playing up... I had a screencast for you but it's not working. things are missing completely from my contribution's page and links are not working.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
admaiora
in reply to: johnsonshiue
Hi, thank you.
I am aware of how Inventor behave in these cases.
I would just want something smarter in these new releases.
I don't want to wait for the selector. I want the most obvious selection available first (as fusion).
I really think that:
-closed loops
-selection areas
will need an improvement.
Thanks!
Admaiora
salariua
It is my understanding that Fusion is a lot better at understanding loops and regions. Maybe we can get the two teams together and improve it.
Nonetheless, @admaiora add this Idea and give us a link to vote for it.
Adrian S.
blog.ads-sol.com
