Select Project File dialog box
ToddPig
ToddPig
Is there a way to set a default so that each time I open a part from the vault (Basic 2015) I don't have to Select the Project File?
In short, I would like to eliminate the step of clicking OK on the dialog box. (see attached)
Todd
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Mark.Lancaster
In the Tools/admin/vault settings (file tab) of Vault client..
Also is there a reason why you have 2 project files in Vault?  I would recommend just having one of them...
Mark Lancaster
ToddPig
see screen capture
Inventor 2018
iParts = iHeadache
mdavis22569
I have 1 ipj (which is checked out, so other users can't modify it and mess it up) ....
You can set it up so it's defaults to what you need to from the start ... and change it as required, or per customer/job...like @Mark.Lancaster was saying
Mike Davis
Mark.Lancaster
That says you are are not a Vault Admin or have admin rights in Vault.  Check with who manages your Vault.
Mark Lancaster
