Select Faces and Edges command on Custom Panel
gordow
gordow
I frequently use the Select Faces and Edges command in the Quick Access Toolbar (QAT).  I would like to add the command to the Custom Panel on the Assemble Tab so I don't have to use the drop down menu, but when I am in Customize User Commands, I cannot find the command when on the Ribbon tab.  When on the Markup Menu tab, I can find it and add it to the Markup Menu, and I can add it as a keyboard shortcut.  I have searched the Ribbon tab but can't find the command there.  Why is it not available for the Custom Panel?
Any insight welcome.  Thanks.
Inventor 2023.3.1
kacper.suchomski
Hi
Do you know Shift + RMB combination?
Kacper Suchomski
gordow
Yes, thanks.  My question relates to how to put the command on the Custom Panel.
