Inventor Forum
Sectioning custom frame members
6 REPLIES 6
fridtjofZM5ME
493 Views, 6 Replies
fridtjofZM5ME
The frame profiles in the content center that come with Inventor are automatically sectioned in drawings. What do I have to do to get the same behaviour from custom frame members. I know I can select the frame assembly in the model tree and choose them to be sectioned each and every time I use them, but I would really like for this to happen automatically.
Labels (2)
6 REPLIES 6
SharkDesign
in reply to: fridtjofZM5ME
SharkDesign
I think this is what you are referring to.
Standard parts from CC are sectioned differently unless you change the setting when placing the view.
I don't think there is a way to do this by default for custom parts.
  Expert Elite
  Inventor Certified Professional
  Expert Elite
johnsonshiue
Hi! The sectioning behavior can be a bit confusing. Aside from the options James mentioned here, you may want to look into Tools -> App Options -> Drawing -> Sectioning Standard Parts. This will control the default sectioning behavior when a CC part is about to cut in a section view.
Many thanks!
Software Test Engineer
Many thanks!
fridtjofZM5ME
Hi @johnsonshiue I see where you're getting at, but it isn't entirely what I'm looking for. I'm aware that I can set Inventor to section everything through the set of options you're refering to, but that only "inverts" the problem. I still want CC-content (screws, washers, ballbearings etc.) NOT to section automatically, while I do want my custom frame members to do so, like your run-of-the-mill I-beam you might place through the frame generator.
I assume that this issue is solved for the CC structural shapes that comes with Inventor through some option not available to the users, but to be able to set the default sectioning behaviour on custom structural shapes is something to concider to add to the authoring functionality in a future version. After all, we all want a feasable way to replicate the behaviours and funcionalities Inventor comes with, in our own work environments. Alternatively, I suppose modifying the option you refer to, to distinguish between the different groups of CC-parts at a lower level in the hierarchy, would also do the trick.
JonathanKruger
It is definitely something inside the Standard Steel Section file that controls this.
I know it may not be the best workaround but have you tried to use the "Copy To" of one of the standard I-beams using the Content Center Editor and then manually edit the "Family Table" to get the desired sizes of the newly copied I-Beam? I have tested it and it seems that when you copy one of there sections it does keep the "I can be sectioned" property.
It is the only way I can see this is possible so that you don't have to apply other workarounds and you original suggestion may be a good Idea Station Idea that I would upvote.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
JonathanKruger
Well you have one UPVOTE from me. Lets hope it is easy to implement
