I have a couple of sheets where I placed section views on a different sheet from the view it’s referencing. However, when I export those particular sheets along with all of my other sheets to Autocad, those section view sheets are not to scale when all of my other sheets are fine. What could be the issue that I’m missing and is there a possible fix to make sections views placed on separate sheets export to scale?
Solved by SharkDesign. Go to Solution.
Your export. When you do the save as, check the options. If it is set to 'base scale' anything on that page will be set to the same scale as the first view you placed (on that particular page). If your section is from a different page, that could potentially be a different scale.
As far as I know you can't fix this. Of all the options, only base scale will show the sections, the others omit it.
Well not how you have it anyway. The only way to get it to work is to make sure your sections are the same scale as everything else on that page.
I don't think this will change. Section views are purely for views, they are not meant to be to scale.
I don't think you're supposed to be put section views on different pages either as you can't easily see what it's referencing. If you request it in the ideastation though they may consider it.
Hi! I am wondering if you may benefit from using AutoCAD VIEWBASE workflow. AutoCAD has the ability to document Inventor components associatively. The command is VIEWBASE. You can create associative drawing views to Inventor parts or assemblies. Then use AutoCAD's comprehensive drafting tools to annotate the views.
Many thanks!
