Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
When I create a Section View the letter that identifies that particular view when created apprears to the side of the arrow (B) by default. Is there a way to change it's default position to be directly in front of the arrow (A) ?
Solved by cbenner. Go to Solution.
In styles manager, under View Annotation. There are several options to control section views.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Okay. Not perfect but much better. Thanks!
No, I fear the perfect solution is not there... but at least we can get it close to what we want and manually adjust from there. Still better than a drafting table, pencil and electric eraser! 😄
Chris Benner
