Section view - part is not participated but Break Out view needed
j.pavlicek
j.pavlicek
there is section view in drawing of an assembly with shaft. All parts are participating in this section except shaft.
This shaft has some assembly related hole which i need to view in drawing. On classic drawings in AutoCAD, I was used to create small Break Out view in shaft. But I can't figure how to do it in Inventor - the shaft is not participating in section, so Break Out is not affects it.
What I want to getWhat I want to getWhat I'm able to getWhat I'm able to getWhat I'm able to getWhat I'm able to get
Thanks for help.
PS: Workaround with breakout affecting all except part of the shaft is not suitable for me. The shaft is in large and complex assembly.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Replies (12)
Sergio.D.Suárez
Hi, see the attached video, it explains how to specify whether the part will participate in the section or not, make sure that the view is associated with the assembly in the drawing. I hope it helps you solve your problem. Greetings.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
j.pavlicek
Thanks for reply. But I'm affraid that your answer is not what I'm asking for. I need to keep same part excluded from section (not participate) and create Break Out view on same part.
Here is video showing my problem better:
https://streamable.com/s/mc05w/tgfhxj
(Bolt has to be without section, long cylinder too - only Break Out so bolt could be fully visible)
johnsonshiue
Hi! I am not sure if this is a good workaround. Please bear with me. I guess for drawing purpose, you can create a derive part of the shaft. In the derived part, cut off the complicated portion and make sure the part BOM Structure is set to Reference (go to Tools -> Doc Setting -> BOM -> Reference). Place this part into the assembly so it overlaps the original shaft.
In the drawing, include this derived shaft for sectioning. Edit the drawing view -> Model State -> set Reference Data as Part.
Could you try it and see if it is what you were looking for?
Many thanks!
Software Test Engineer
j.pavlicek
Thanks for reply. But I'm not sure that I understand properly.
Do you suggest to create derived part where the problematic part will be cutted of (from 3D model) and then display this part in a drawing? Like this: https://streamable.com/mkwg4?
j.pavlicek
Better images are below:
What I'm able to get (all parts are participated)What I'm able to get (all parts are participated)What I'm able to get (long cylinder is not participated)What I'm able to get (long cylinder is not participated)What I'm able to get (longer cylinder is not participated, Break Out i sectioning all parts)What I'm able to get (longer cylinder is not participated, Break Out i sectioning all parts)What I want to getWhat I want to get
johnsonshiue
Hi! Yes, it is what I had in mind. Essentially, you need to create another part (derive) just for sectioning purpose. It should not contribute to mass prop or BOM though.
Many thanks!
j.pavlicek
Please see video. I receive two overlaping parts with your suggested approach.
johnsonshiue
Hi! The Break Out view does require section participation. Maybe, you can set the first part as transparent (right-click on the part in the drawing browser -> check Transparent). But, I don't think it will help since you will still see the back edges of the uncut part. I am sorry.
Many thanks!
WHolzwarth
In 2014 I created a similar wish in Ideastation. 69 votes until now
https://forums.autodesk.com/t5/inventor-ideas/improvements-for-breakouts-in-sections-needed/idi-p/53...
Walter Holzwarth
j.pavlicek
So only solution for now is to vote for: Improvements for breakouts in sections needed.
Thanks everyone for replies!
WHolzwarth
Smiley Frustrated It's some kind of breeding stalactites ..
Walter Holzwarth
Yijiang.Cai
It should be fixed in 2023.1, and you can get more details in Help page.
River
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
