Hi all.
I have just created a part with a bearing on. When I create a 2D sectional view, the bearing is displayed as being a solid plain block.
How can I add section views to it? I have tried the section participation from the browser, but this does not help.
Sam.
Solved by Marco.Takx. Go to Solution.
Hi! In the drawing view, go to the browser -> right-click on the assembly node -> Section Participation -> select All.
Many thanks!
Hi Johnson.
I tried that, but regardless of whether I tick section, slice or none from the section participation tool, the drawing does not change.
Sam.
This is what @johnsonshiue meant.
If my post answers your question Please use
.Accept as Solution &
Kudos This helps everyone find answers more quickly!
