Inventor Forum
section view / labelling
2 REPLIES 2
pbainKCQSW
271 Views, 2 Replies
I have a few questions,
1. When i add my first detail, it defaults to "C" how do i reset this to "A" (see screen shot # 3)
2. i want my section views to be 1,2,3 etc, NOT A,B,C etc.
3. when i add my first base view as front, my view label says a random "view38" although my view preference says <view> it's not picking it up based on the model cube, how do i do this ? (see screen shot # 1,2,4,5,6)
2 REPLIES 2
Gabriel_Watson
in reply to: pbainKCQSW
First, you can only include up to 3 attachments, so we only have 3 of your screenshots.
Secondly, make sure you are NOT working on a copied drawing instead of starting a drawing from a blank template using the "new" drawing function in Inventor (which should make sure the label count starts from zero).
Thirdly, there is no easy way to relabel all views except manually, or apparently through a paid plugin:
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=8979825751121444479&appLang=en&os=Win32_64
Make sure to vote for this idea to push for a change that allows such functionality in-box:
https://forums.autodesk.com/t5/inventor-ideas/feature-sketch-numbers-reset-ability/idi-p/4378343
More on this thread:
https://forums.autodesk.com/t5/inventor-forum/how-do-i-reset-the-view-identifier-number-in-the-idw/t...
A.Acheson
in reply to: Gabriel_Watson
You will need to use ilogic to rename view label to numeric value. It will find label with A and change to 1 etc. If your need is alot it would be justified to spend the time.
Regards
Alan
Technology Administrators
