Sculpt Command Issue
ztdservices
Message 1 of 9
ztdservices
Good Morning
Having an issue with the sculpt command whereby it wont let accept my selection and the ok box remains greyed out.
Any ideas
All services packs and hotfixes have been installed.
Thanks in advance
Jason
Replies (8)
Message 2 of 9
admaiora
What do you want to obtain?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
ztdservices
Hi
the highlighted part needs to be removed (sculpted from the body) so the main body appears to have a threaded profile.
Jason
Message 4 of 9
admaiora
Not sure what do you mean.
Anyway Sculpt command doesn't work that way.
It create a solid from a closed surfaced space.
To remove feature you can suppres them.
Admaiora
Message 5 of 9
ztdservices
I started with the copy object command to add the threaded details to the main body, then selected the sculpt command to removed the selected option. I have done this before and it has worked in the past, hence the reason why I m scratching my head with this just now.
Message 6 of 9
Hochenauer
The OK button is not enabled because your selection does not enclose a volume. It looks like you selected a single planar face. The Sculpt command turns a set of arbitrary intersecting surfaces building a closed volume into a solid.
Does this make sense?
From your description I gather you want to create a shaft with an outside thread where the hole currently is?
regards,
Gerald
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
Message 7 of 9
ztdservices
the thread is internal (at one end)
Message 8 of 9
Hochenauer
Ok, your input is a solid. I was able to use sculpt after deleting a face from it:
SculptSculpt
For Solids, you can use the Combine command:
combinecombine
I hope this helps.
Kind regards,
Gerald
Gerald Hochenauer
Autodesk, Inc.
Message 9 of 9
ztdservices
Thank you very much Gerald 🙂
Kind Regards
Jason
SculptSculpt
combinecombine
I hope this helps.
Kind regards,
Gerald
