Screws(machining hole) with side thickness parameter
janarT35FJ
janarT35FJ
Hi!
Is it possible to make screw drilling holes iBox component which i can add to cabinet top or bottom panels?
I would like that - When i add iBox with drilling holes into top or bottom panels in cabinet, then form pops out and i can add sidepanel thickness. Drilling hole in top or bottom panel is 35mm depth and sidepanel thickness is changable.
I would like to know what rule it should be with iLogic.
Thanks for attention! 🙂
SBix26
This involves programming and would be more appropriate in the Inventor iLogic, API & VBA Forum.
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
johnsonshiue
Hi! I am sure it is doable. But, it is very difficult to illustrate the approach without an example (machining hole). Please share an example of what you are attempting. It will facilitate the discussion.
Many thanks!
Software Test Engineer
janarT35FJ
Hi!
I am sending pack_n_go file which i am trying to do.
J.
johnsonshiue
Hi! Many thanks for sharing the files!  The parameter "kp" in the assembly is linked from kruvid.ipt. It cannot be changed. Do you want to change the value of "kp" at the assembly level? If yes, you don't need to link it to the assembly. There is no need to link it to other parts either.
Simply place kruvid.ipt into the assembly and make it invisible. You can write a rule accessing the parameter. In the iLogic rule at the assembly level, you can access parameters from all components within the assembly.
Thanks again!
janarT35FJ
Thanks for help and attention! I will try to fix this.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
