Scaling issue after stp file has been imported
kristofszigeti1
Message 1 of 16
kristofszigeti1
Hi there,
When I import, it seems as if the inventor changed the original model scale. Why does it happen or what do I miss?
There is a length 73,118 mm but Inventor says it is 2,868.
Replies (15)
Message 2 of 16
EdvinTailwind
I think it's a metric versus imperial issue.
1 inch= 25,4 mm
2,868 * 25,4 = 72,8472
That is very close to your expected measurement. The deviation of 0,2708 could be depending on the precision during export and import of the STP.
Message 3 of 16
kristofszigeti1
It is close and this must be the issue, but a bit unexpectable, that is why I'm surprised.
btw obj file seems properly (in the right scale) imported. I might be able to working with this in this situation.
Message 4 of 16
EdvinTailwind
In worst case you could create a derived part and scale it by 25,4.
Message 5 of 16
JDMather
@kristofszigeti1
You mention stp and obj.
stp units usually specified from source
obj no units and often rubbish
Attach your original file(s) here and end all doubt.
The should be a logical reason/solution.
Message 6 of 16
johnsonshiue
Hi! STEP file is unit sensitive. Unless the unit is incorrectly specified in the file, I don't think the model will rescale. I guess you were talking about the original source being mesh (obj). And, it was imported and converted to a solid body. Then it is exported to STEP. The rescaling probably happen during obj import.
Please share the file here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 7 of 16
kristofszigeti1
Let me share you some files.
The task is: There are plenty of hollow section parts which designed in Tekla Structures and all of them need to be handled by hand-sawing process, so I would like to make a cover or a mask to mark the proper line for it. After importing they are supposed to be unwraped and exported to 1:1 dwg/dxf, but they seem like smaller as I expected and the ratio is around the imperial <-> metric conversation.
It is supposed to be right. I am pretty rookie user of Inventor, so I must miss something!
Message 8 of 16
johnsonshiue
Hi Kristof,
The STEP file is based on mm. You can open it in Notepad to check the coordinates. They are all in the range of hundreds of mm, which is consistent with the measurement of the STEP imported geometry in Inventor and viewer.autodesk.com.
I suggest you look into "Open CASCADE," since the STEP file was exported by the tool. There could be some setting to change to ensure the proper scaling.
Many thanks!
Message 9 of 16
JDMather
@kristofszigeti1
OK,
Let's back up and establish some base information.
The Units in your DWG file is Inches
The Units in your *.ipt is also inch.
Do you want inch units or do you want metric (mm) units?
Message 10 of 16
kristofszigeti1
mm values is needed in all of the files and documentations.
I am pretty newbie at using Inventor, I guess I confused myself, too. Skipping a basic step or something like this.
Thank you for helping me out!
Message 11 of 16
JDMather
@kristofszigeti1
How are you “opening” the stp file?
Are you doing File>Open directly
or
are you Importing into an already open file?
Message 12 of 16
kristofszigeti1
Just import the stp file just as it has been exported from Tekla.
Starting Inventor, opening a session by the "Part" button, and after that importing stp, setting multi-body part and selecting the stich option from the drop-down menu.
Message 13 of 16
TheCADWhisperer
@kristofszigeti1
Stop.
Do you normally work with metric units?
It sounds like your default template is set to inch units.
We can change the default units if you normally work in mm.
But if instead of starting the way you describe, don’t start a New Part. Don’t Import.
Go to File>Open and select Files of Type *.stp and open directly rather than importing into an already open file.
Let me know if you want to change your default units.
Message 14 of 16
JDMather
To Open the *.stp file directly ...
To change Default Template (for all future work)...
To change (or check) the Units of existing work...
Message 15 of 16
kristofszigeti1
Thank you very much!
(I will keep on learning.)
Message 16 of 16
kristofszigeti1
(I will keep on learning)
