Scale origin using Direct Edit
andrewdroth
Advisor Advisor
Message 1 of 10
andrewdroth
There doesn't seem to be a way to use the part origin to scale a body, only a faces. Is that true?
There also doesn't seem to be a way to edit an origin after the feature is created.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (9)
Message 2 of 10
blair
If you use the "Derive" function, you can then use the Scale>Vector option which will then reference the model Origins. The Push/Pull can be directing in different directions by manipulated it's work-screen Tool-Icon.
The Move-Body command will change the Body with respect to the Origin.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 10
andrewdroth
Yeah I know I can do the same thing with a derive, I just wanted to keep the scaling within the same part.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 4 of 10
swalton
I'm not sure what you are trying to do, but how about the Direct Edit tool with the Scale option?
https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-3C3258FE-E5B2-4219-BE90-BD8011580855
That tool should also let you move/rotate the body geometry relative to the part origin geometry.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 10
johnsonshiue
Hi Andrew,
You could also use Direct Edit -> Body -> Move to relocate the body so that it is in a different place relative to the origin.
Many thanks!
Software Test Engineer
Message 6 of 10
andrewdroth
Yes. That's what I'm using... But I cannot set the point at which it scales from to the part origin.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 7 of 10
swalton
What do you mean: "scales from to the part origin"?  Do you want the part geometry to move relative to the part origin by the scale factor?
Steve Walton
Inventor 2025
Message 8 of 10
andrewdroth
Yes.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 9 of 10
swalton
Ok.  Now I understand.
The issue (I'm using Inventor 2019.4) is that the scale tool won't select work geometry (like the Center Point) as the Triad Location to use as the origin point of the scale operation.  Why? Autodesk programed the tool that way.
Workarounds:
  1. Use two steps, one to scale the solid, the second to move it the required offset.
  2. Make some helper geometry:
    1. Create a new solid body with a midpoint or end of an edge at the Center Point of the part file.
    2. Use the Direct Edit-Scale command and select the edge center or end point created in Step 1.
    3. Scale the object.
    4. Create a new feature to cut away the helper geometry.
If you create an Idea post requesting the ability to select work geometry for the Triad Location with the Scale tool, I'd vote for it.  If it gets enough votes, Autodesk may add this reasonable functionality in the next 4-5 releases.
Steve Walton
Inventor 2025
Message 10 of 10
andrewdroth
I just split a tiny circle at the origin and used that face to drive the Direct Edit scale triad.
I'll look into making an idea station post.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
