Announcements
SCALE/DIMENSION IMAGE IN DRAWING
0x3FA5
0x3FA5
It seems strange for such a simple task, but it looks that I am missing something.
I have a set of drawings of different sizes, to which I would like to add an image. Since the drawings are different in size, the image needs to be scaled/dimensioned.
This is how I tried to solve the issue:
(1)
Manage -> Insert Object -> From file
Right click on the image, looking for scale/size options. NONE.
Double click on the image - just opens the image in editor.
(2)
Start new sketch.
"Insert an image file into a sketch" : Image is grayed out.
(3)
Created AutoCAD drawing, trying to insert through
Or
Manage -> Insert Object -> Create New -> AutoCAD Drawing
Getting the same error:
(4)
Created new Inventor part, created sketch
Added dimensions.
Went back to the initial drawing, Place Views -> Base -> ...Part
Nothing appears, even though all items are checked as "Visible"
Any ideas?
Many thanks!
luisalfredovazquez1995
0x3FA5
I cannot see the details on the animated picture, can you please explain/translate?
Thank you!
JDMather
Right click on Sketch Symbols.
Select Define New Symbol.
Place you image.
Sketch a line over image.
Dimension the line to desired size.
Click on image.
Drag corner of image to scale to match the dimensioned line.
Delete the line.
Save the Sketch Symbol.
0x3FA5
Actually, I cannot scale it either, so it is not really a solution..
0x3FA5
Thank you,
The problem is that the picture snaps to top left corner only, the opposite corner does not snap to line..
But I am half way there, thank you!
