Saving Inventor DWG as AutoCAD DWG
tschaeferZNBXX
Advisor Advisor
Message 1 of 10
tschaeferZNBXX
I know I can use the "Save Copy As" but is there a way to default Inventor to save DWG files as AutoCAD DWG files?
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Replies (9)
Message 2 of 10
mcgyvr
No but you can use Inventor.dwg files instead of idw files to allow you to work between both programs easier..
Message 3 of 10
Curtis_Waguespack
Hi tschaeferZNBXX,
To add to mcgyvr's suggestion, you can go to the Tools tab > Application Options button > Drawing tab and change the Default Drawing File Type setting
Sets the default drawing file type (.idw or .dwg) when creating a drawing using New Drawing on the Quick Access toolbar.
I hope this helps.
Curtis
Message 4 of 10
tschaeferZNBXX
Yes but we have individuals that want to copy and paste from a DWG to an AutoCAD DWG. I know its the old way but we still have people doing this.
I have changed all the settings to Inventor DWG and have our templates set to Inventor DWG.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 5 of 10
mflayler
What is it that they copy and paste from?  Do they just need the views from Inventor?
If Yes... You can use Deisgn Center to bring in views from Inventor DWGs and they can be updated similar to X-refs when the Inventor DWG updates, so do the placed references in whatever ACAD file you put them in.
If No...May the big guy upstairs give you strength to overcome whatever they are doing with your geometry after they copy and paste it.
Also, be aware of storing these files in folders that are obviously AutoCAD or Inventor, you will never be able to tell in Windows Explorer.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 6 of 10
tschaeferZNBXX
That is the problem. We have some individuals who are stuck in old school AutoCAD and do not want to learn Inventor. I am in a rock and hard place but I will deal with it. 🙂
*AU Speaker 2018*
* AU Speaker 2017 *
Message 7 of 10
mcgyvr
Their manager can easily deal with that... Inventor or out the door is how I would handle that..
Message 8 of 10
tschaeferZNBXX
I agree 100% but we currently do not have a manager
*AU Speaker 2018*
* AU Speaker 2017 *
Message 9 of 10
mcgyvr
Surely someone is "in charge" there.. Owner? President?
You can't just all run wild..
What happens when you spread a line of coke on your desk? Who addresses that?
Allowing employees with similar job functions to use multiple programs is stupid..
Consistency is key to running a company properly..
But yes.. sometimes old people suck Smiley Very Happy
Message 10 of 10
tschaeferZNBXX
I am trying to get control but I have been in this position before and refuse to do it for free or without a change in job title.
*AU Speaker 2018*
* AU Speaker 2017 *
