Create a part without ANY mounting features. Derive the part and add one
mount. Derive a second from the original and create the second mount.
Change the original and both derives will update.
Alternatively, make your part an iPart with both mounts suppressed.
Determine which one on instertion.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:6025684@discussion.autodesk.com...
I have a part that is going to be mounted by 2 seperate methods. This means
that I need to finish the part with 1 mounting arrangement, save
it.........Then I need to open that same part and alter the mounting
arrangement, and save it as a 2nd part. Can I do this without it updating
the original?
I was going to attempt to build the main part, the 1st mounting as a part,
and the 2nd mounting as a part, and then make two seperate assemblies, but I
would have to do some additional work within the assembly, and as far as I
can recall you can only subtract material in an iam, not add material.
Any advice?
INV 09
