Save file from step to iam
silviu.bunu
Message 1 of 10
silviu.bunu
I have a situation when I want to save a step file to Inventor. The situation is the one from the Capture picture. Because of that when I hit the OK button, from the Capture2 picture, all files are saved on my computer.
There is a possibility to skip that step when I want to save that file?
Thank you in advance for your support.
Replies (9)
Message 2 of 10
Cadmanto
@silviu.bunu
Are you saying you want the step file when saved to remain one single file?  And not create all of the individual files?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
silviu.bunu
Message 4 of 10
Cadmanto
@silviu.bunu
As shown in this link, there are a couple options
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
My thinking is after this step file is converted, create the derived part using this assembly.
But, with all of that said, I am thinking this is not the solution you are looking for.  Sounds like you want a way to receive a step file in a format that when translated into Inventor is a single file.  The only way to do this is who ever you are getting the step file from, have them make a derived part and export that as a step file.  That would give you what I think you are looking for.
Inventor Pro 2021
Best Regards,
Scott McFadden
Message 5 of 10
SBix26
Rather than open the STEP file in Inventor, create a new part file and then Import the STEP file.  In this way all the component parts become separate bodies but all in one part file.
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
Message 6 of 10
silviu.bunu
@SBix26
could you please share a tutorial or a link how can I create a new part file and then Import the STEP file?
 @Cadmanto I will try those 2 solutions from the link provided by you, but as you said when the file is translated into Inventor should be a single file.
After I will try those solutions I will come back with a feedback or even I will accept a solution.
Thank you.
Message 7 of 10
silviu.bunu
 @Cadmanto I tried both of them and does not work. Thank you for the support tho.
Message 8 of 10
SBix26
Step 1: Create a new part file (.ipt) from your preferred template
Step 2: Click on the Import tool in the Create panel
Step 3: In the Import dialog box, select the STEP file you wish to import
Step 4: Options as desired for the imported part; OK
Step 5: Save the file
Now you have a part file containing the entire STEP assembly, as you wanted.
Sam B
LinkedIn
Message 9 of 10
johnsonshiue
Hi Silviu,
Scott is right. Starting a new part and import the STEP is the way to force an assembly STEP file to become a multi-solid body part. Make sure all geometry types are checked in the Import dialog. If it still does not work, please share the file here. Forum experts can help take a look.
Many thanks!
Software Test Engineer
Message 10 of 10
silviu.bunu
@johnsonshiue  and @SBix26
I will test it and come back to you and accept the solution if that works.
Thanks.
