Save as part in assembly
ZFerrarini
ZFerrarini
I am used to Solidworks where from an assembly I open a part and do a "save as" with a different name, and the assembly gets updated with the new part.
I tried to do the same in Inventor 2023, but I can't make it work.
The only way I found is to do the save as, but the assembly doesn't keep the new part and then I replace the old part with the new one.
Is this really the only way or am I doing something wrong?
Is there a way to do the save as like Solidworks?
Thank you in advance.
kacper.suchomski
Hi
Save and Replace?
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-BCC5604E-DC96-4772-8DF4-60AA2541D4B3
Kacper Suchomski
ZFerrarini
Thank you.
ZFerrarini
One more question: does it work with the drawing of the part I want to rename?
kacper.suchomski
No. A new part requires a new drawing. Depending on your needs, you can:
  1. Save a copy as (new name), open a copy, swap reference.
  2. Open drawing, swap reference, save (or save as).
  3. Create a new drawing with the new part.
Kacper Suchomski
ZFerrarini
That sucks. Thank you.
