Same name for every imported STEP file
martijn.buse
martijn.buse
Hi there,
I am having some issues when importing STEP files. Every STEP file that I import into Inventor 2022, gets the same name (in the tree). I saved a file once with a specific name and that now seems the default name for every imported STEP file. If I fill in a prefix or suffix in the import window, then it does change the entire name. I hope someone can help me out.
With kind regards,
Martijn
CCarreiras
The name in the tree?! Can you give an example, image and/or file?
CCarreiras
martijn.buse
So for example I have 3 different STEP files named:
A.stp
B.stp
C.stp
When I open and import each of these files seperately in Inventor, they all show up as:
D.ipt
CCarreiras
Have you all the updates installed? (2022.4)
CCarreiras
martijn.buse
Aha, that did solve the problem for now. Thanks a lot!
