is there a way to have the same assembly with different dimensions and parameters in an assembly? Like its possible with iParts.
Regards
Hi!
Yes, it's possible with iAssemblys or with iLogic, deppends what you want to achieve.
Making a parametric modelbased in rules and link parameters between parts, etc etc etc...
Hi!!
Not true... you can have multivalue parameters,text parameters, boolean parameters... and lots of rules to apply.
It will go a lot further then iAssembly, but for some cases, iAssembly is enought... again, deppends!!!
Tell us what you really wanna do and we will help you.... talking about scenarios without knowing the objective... is just a boring theoretical conversation...
Hi!
Ok, so you have to create a parametric model to have the possibility to generate new different assemblys, changing parameters in the parametric model.
You can have infinite possibilities!!
So it will work like, open the parametric model, change parameters, create a assembly version and place it inside Master assembly.
Be aware, new assemblys, some different parts (in size at least), therefore new part numbers, It's possible to do that automatically with some code, but you can also use some tools to do that, like iLogic copy, design assistant, etc.
