SAEJ926 HOLE (ET AL)
Jeff_Moss
Message 1 of 15
Jeff_Moss
Are there already SAE spec hydraulic hole ports in Inventor 2024? I just upgraded from 2022 and don't see 'em yet. Maybe I don't know where to look, but I REALLY don't want to have to set this up as a custom hole/pocket.
I'm dragging and dropping a hole-pocket spec sheet for all the SAE hydraulic fitting holes.
This'd be immensely helpful...and I'm told that Brand-X already HAS it...
Jeff
Replies (14)
Message 2 of 15
johnsonshiue
Hi! I could be wrong but I don't think the specific feature is available in Inventor unfortunately.
Many thanks!
Software Test Engineer
Message 3 of 15
Frederick_Law
Make your own iFeature
Message 4 of 15
tlebrun
Fred,
Is there a way to add the ifeature to a diameter?  I have a work plane on the outer diameter of a cylinder, with a sketch, but, no matter what i do, it can't build the feature.
Message 5 of 15
Frederick_Law
Yes.
What are you trying to build?
Message 6 of 15
tlebrun
sae portsae port
We use SAE ports all the time, and I just discovered today about the custom ifeature.  I tried to use it but it just doesn't want to work with cylinders.  Currently we just create a tapped spotface hole, then add the chamfers.  I can add the ifeature easily to any flat surface but not on a work plane tangent to a cylinder.
Message 7 of 15
Frederick_Law
Might need different iFeature for flat and cylinder.
It'll depends on the first feature.
Depends on cylinder diameter, the flat will need different depth.
Message 8 of 15
tlebrun
I could add the spotface, and add the ifeature to it, but that would defeat the purpose of simplifying the task.
Kind-of silly ifeatures don't work on cylinders.  Hopefully the SAE hole be added to a future revision of Inventor.
Message 9 of 15
Frederick_Law
It should be doable.
A simple extrude cut iFeature on cylinder.
Message 10 of 15
Jeff_Moss
I agree it should be doable...even on cylinders. BUT...my point is: "Autodesk ought to wake up and make this functionality available to us."
I do hydraulic ports as an OCCASIONAL design feature. It makes no sense whatever for me to spend the inordinate amount of time relearning the i-feature process to create such a widely-used feature creation tool. I'm not the only soul who designs machines that OCCASIONALLY have hydraulic subsystems. I have 2.8 engineers here where I work, and we keep ALL our product design work done for a job-shop-organized effort to ship machines from four widely-divergent product-lines worldwide.
I'll eventually cave and DO it, but I don't WANT to. Seriously, why do I have to do Autodesk's job on MY weekends, evenings and mornings?
Message 11 of 15
Frederick_Law
There was no reason to model it.  All was required was a note saying "-8 SAE o-ring port".
Anyway, I tested my SAE port iFeature and it works LOL.
Message 12 of 15
claudio.ibarra
I came across this thread looking for a better way to add SAE ports to parts.
Where I work, we have .ide for SAE iFeatures, but there's a glaring problem --- putting it in a welded component. iFeatures don't play in assemblies. So we have to try and put the feature in the part level and take steps to hide it.
Is it a herculean effort to add SAE to the holes.xls file?
Message 13 of 15
hollypapp65
Yes.
ModelState could hide the SAE port.
Or convert assembly into Weldment.
Message 14 of 15
claudio.ibarra
Wait, do iFeatures work in Weldment assemblies? I thought they only work in .ipt files, because .iam features are restricted to things that remove material, and iFeatures can theoretically add material.
Why is modifying the holes.xls file a herculean (or sisyphean) effort? Autodesk, make it easy! I came here looking for a way to make a modification so I can have counterbore holes with and without high-collar lockwashers, but it's easier to provide everyone with a PDF cheat-sheet at their desks. That shouldn't be the case in the 21st century!
Message 15 of 15
nagihan.bostan
Hi everyone,
We developed Logic Hydraulic Port Creator — an Autodesk Inventor plugin that automates hydraulic port creation for ISO 1179-1, SAE J1926-1 and ISO 6149-1 standards. It generates the thread, spotface and chamfer geometry automatically on both cylindrical and flat surfaces, directly from the Inventor toolbar.
There's a 2-week free trial on the Autodesk App Store if anyone wants to give it a try:
👉http://logicps.net/download-hpc
