Inventor Forum
Run rule when sheet size is changed
4 REPLIES 4
fakeru
1169 Views, 4 Replies
Hi!
I have created a rule that will replace the border sheet when the sheet size will be changed, so users won't have to do it manually.
The problem is that the rule won't run when the sheet size is changed. I find that events for triggering the rules are rather few under drawing enviroment.
I thought to use "iProperty Change" event, providing I assign the SheetSize to a Custom iProperty, but the iProperty won't update automatically as well.
Any ideas what could help?
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
4 REPLIES 4
fakeru
in reply to: fakeru
Nothing? 😞
jletcher
in reply to: fakeru
posting your code would help.
 Also if you post ilogic or VBA questions in the Inventor Customization would get more answers.
 I have an ilogic rule that changes sheet size, title block and border works when new document is started.
 Where do you have your trigger set where is it in your code all this will be needed before anyone can help.
fakeru
in reply to: jletcher
Here is the code:
kLandscapePageOrientation = 10242
kPortraitPageOrientation = 10243
CurrentOrientation = ThisApplication.ActiveDocument.ActiveSheet.Orientation
If ActiveSheet.Size = "A4" And CurrentOrientation = 10243 Then
ActiveSheet.Border = "A4 Portrait"
'A3 Portrait
If ActiveSheet.Size = "A3" And CurrentOrientation = 10243 Then
ActiveSheet.Border = "A3 Portrait"
'A3 Landscape
If ActiveSheet.Size = "A3" And CurrentOrientation = 10242 Then
ActiveSheet.Border = "A3 Landscape"
'A2 Portrait
If ActiveSheet.Size = "A2" And CurrentOrientation = 10243 Then
ActiveSheet.Border = "A2 Portrait"
'A2 Landscape
If ActiveSheet.Size = "A2" And CurrentOrientation = 10242 Then
ActiveSheet.Border = "A2 Landscape"
'A1 Portrait
If ActiveSheet.Size = "A1" And CurrentOrientation = 10243 Then
ActiveSheet.Border = "A1 Portrait"
'A1 Landscape
If ActiveSheet.Size = "A1" And CurrentOrientation = 10242 Then
ActiveSheet.Border = "A1 Landscape"
'A0 Portrait
If ActiveSheet.Size = "A0" And CurrentOrientation = 10243 Then
ActiveSheet.Border = "A0 Portrait"
'A0 Landscape
If ActiveSheet.Size = "A0" And CurrentOrientation = 10242 Then
ActiveSheet.Border = "A0 Landscape"
 I can run it with itrigger, but that's not the idea, because other users don't use ilogic. I have lots of ilogic rules in different inventor files that other users don't even know about them, those rules run in background without interacting with the designers.. Most of them won't like the idea of pressing a button (itrigger), they are not used with ilogic things. I just want it to be automatically done by Inventor.
jletcher
in reply to: fakeru
The trigger is silent they will be prompt at the start and they will pick option the tigger makes it happen but they don't have to do anything but pick.
Make it ask them when new template is used.
 My code is not what you are after but you may get the idea. My ilogic is used to ask what sheet size to use all are in landscape and also changes the styles.
 But you may get the idea what to do.
In the fx you will make a list of options..
trigger=iTrigger0
Dim drawingDoc as DrawingDocument = ThisDoc.Document
Dim stylesMan As DrawingStylesManager = drawingDoc.StylesManager
Trace.WriteLine(" --- Active drawing standard = " & stylesMan.ActiveStandardStyle.Name )
'Pick Sheet Size
Sheet_Size= InputListBox("Select Sheet Size", MultiValue.List("Sheet_Size"), Sheet_Size, Title := "Sheet Size", ListName := "Choose Sheet Size")
'A size
If Sheet_Size = "A (8 1/2 X 11)" Then
ActiveSheet.ChangeSize("A", MoveBorderItems := True)
ActiveSheet.TitleBlock = "your info"
ActiveSheet.Border = "your info"
stylesMan.ActiveStandardStyle = stylesMan.StandardStyles("your info")
'B size
ElseIf Sheet_Size = "B (11 X 17)" Then
ActiveSheet.ChangeSize("B", MoveBorderItems := True)
'C size
ElseIf Sheet_Size = "C (17 X 22)" Then
ActiveSheet.ChangeSize("C", MoveBorderItems := True)
'D size
ElseIf Sheet_Size = "D (22 X 34)" Then
ActiveSheet.ChangeSize("D", MoveBorderItems := True)
'E size
ElseIf Sheet_Size = "E (34 X 44)" Then
ActiveSheet.ChangeSize("E", MoveBorderItems := True)
'update all
InventorVb.DocumentUpdate()
'zoom all
ThisApplication.ActiveView.Fit
