I currently have a rule and form attached to it that I set the parameters to provide the rule instructions on which sub the rule needs to run when I click the form rule button. Is there a way to have a button only run one of the subs, or do I need to have a rule for each button?
These are simple tasks like reorganizing the parts list, adding center lines etc.
I have access in the form to do this but I have to double check the settings to make sure I don't change something by mistake. Having a one click button would eliminate the time to choose the inputs and chance of choosing incorrectly.
It' also nice to leave the parameters set for process flow so I don't have to change back and forth a lot from one page to the next.
Solved by Curtis_Waguespack. Go to Solution.
Hi @Brian.Price
I'm not sure I follow all of what you're asking/saying, but here's one method.
Also just as an FYI programming questions of this type are better asked on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Set up a main rule with the subs
Sub Main oWhatToRun = RuleArguments("Action") If oWhatToRun = "Sub1" Then Call Sub1 Else If oWhatToRun = "Sub2" Then Call Sub2 Else If oWhatToRun = "Both" Then Call Sub1 Call Sub2 End If End Sub Sub Sub1 MessageBox.Show("Sub1", "ilogic") End Sub Sub Sub2 MessageBox.Show("Sub2", "ilogic") End Sub
Then set up "button" rules that run the main rule with an argument that is used to choose which sub to run:
Dim map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap() map.Add("Action", "Sub1") iLogicVb.RunRule("Rule 001", map)
Dim map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap() map.Add("Action", "Sub2") iLogicVb.RunRule("Rule 001", map)
Dim map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap() map.Add("Action", "Both") iLogicVb.RunRule("Rule 001", map)
I hope this helps.
Curtis
Thanks for the help but I think there is come confusion on my part.
I have a long rule with multiple subs in it.
I would like a form button that runs one of those subs simply by clicking it.
Similar to if you just add the rule to the form it will run that rule.
This way I don't have several rules and only one that does what I need.
Perhaps it would be better to have multiple rules with a button for each.
This is my current form
The first one is the settings to run the rule, the second is a button for each simple task rule that I have.
The button "Punch it Chewie" executes the main rule.
Hi @Brian.Price
If you don't want to break the rule up, I think you could easily use the approach I laid out earlier, which was to set up rules to be used as buttons, to send an argument to the main rule which tells it which sub or subs to run...
....but in looking at the list of tasks you have in your buttons I would actually have those tasks as separate rules (which can be a benefit for debugging, etc. ) and then I would have the "Punch it Chewie" rule use the RunRule or RunExternal rule line to call the rules in the order you prefer, this should give you the best of both worlds.
I hope this helps.
Curtis
this would be the "Punch it Chewie" rule
'run internal rules iLogicVb.RunRule("Replace Centerlines") iLogicVb.RunRule("Export Drawings") iLogicVb.RunRule("PDF") 'etc...
'or use this if the rules are external iLogicVb.RunExternalRule("Replace Centerlines") iLogicVb.RunExternalRule("Export Drawings") iLogicVb.RunExternalRule("PDF") 'etc...
Ok I think I get it now. Any way I look at it there will be a rule to use the button.
@Curtis_Waguespack Any reason the line
would result in the error "'RuleArguments' is not declared. It may be inaccessible due to its protection level"?
Hi @eric.frissell26WKQ ,
It looks like my post above was kind of laid out backwards in the past, but hopefully this provides some clarity.
That is the 2nd part of the rule arguments use case.
This rule, called "Rule Sub1" calls up another rule called Rule 001, and provides an argument that tells it which sub routine within Rule 001 to run. So this is saying "run Rule 001, subroutine Sub1"
This is Rule 001
I hope this helps.
Curtis
Ah, that makes sense! The rule creating the argument needed to be created before the rule that the argument is being passed too... Thanks! Pretty familiar with VBA but first iLogic rule...
Question then. I created the "Sub1" rule which will inevitably pass "action" to Rule 001 so is it possible to run Rule 001 directly (i.e. will it retrieve the argument from Sub1 without Sub1 being ran), or do you need to run Sub1 to pass the argument?
Good question.
Yeah, in this case the goal was to have 3 buttons to run the main rule, in different ways. So that is why the example is creating the other rules and passing arguments, simply to provide a button on the user form.
But we could get the user input via a message box and keep it all in the same rule, such as this:
Sub Main Dim oList = New String() {"Sub1", "Sub2", "Both" } oWhatToRun = InputListBox("Select what to run", oList, oList(2), "ilogic", "List") If oWhatToRun = "Sub1" Then Call Sub1 Else If oWhatToRun = "Sub2" Then Call Sub2 Else If oWhatToRun = "Both" Then Call Sub1 Call Sub2 End If End Sub Sub Sub1 MessageBox.Show("Sub1", "ilogic") End Sub Sub Sub2 MessageBox.Show("Sub2", "ilogic") End Sub
I hope this helps.
Curtis
and/or something like this, if we want to get the input in different ways:
Sub Main 'get argument value from another rule oWhatToRun = RuleArguments("Action") 'if value is empty then get user input If oWhatToRun = "" Then Dim oList = New String() {"Sub1", "Sub2", "Both" } oWhatToRun = InputListBox("Select what to run", oList, oList(2), "ilogic", "List") End If If oWhatToRun = "Sub1" Then Call Sub1 ElseIf oWhatToRun = "Sub2" Then Call Sub2 ElseIf oWhatToRun = "Both" Then Call Sub1 Call Sub2 End If End Sub Sub Sub1 MessageBox.Show("Sub1", "ilogic") End Sub Sub Sub2 MessageBox.Show("Sub2", "ilogic") End Sub
This looks like the perfect way to accomplish getting the ability to run the rule from the rule or externally from a form. Quick question though regarding the code: These two lines
End If
Will oWhatToRun return a null value which errors when calling "Action" later or does returning a null value result in an error?
Thought was rather than
it could be replaced with the error function
If Err Then
End If
Not sure if that would make it any more robust or just accomplish the same thing slightly differently
