Rule Trigger on component move
Message 1 of 9
I made a rule that updates the length of a spring when the arm moves up and down.  My problem is I have to manually run the rule to update the spring length whenever I change the angle of the arm.  I was wondering if it was possible to have the rule trigger whenever the arm moves.
Replies (8)
Message 2 of 9
mcgyvr
Have you seen this? and similar tutorials?
https://designandmotion.net/autodesk/inventor-adaptivity-and-springs/
Message 3 of 9
CCarreiras
Hi!
Depends on how you did that... but yes, it's possible.
You can trigger the rule after a changed dimension, or after saving the files.
Also, you can just trigger the rule from another part...
CCarreiras
Message 4 of 9
I have the event triggers set up like that but it doesn't update when the assembly moves.
Message 5 of 9
Im gonna try that out.  I haven't really messed with the adaptivity stuff yet.
Message 6 of 9
CCarreiras
Well... like i said, deppends on how you did that.
If you post the files here, we can check that.
CCarreiras
Message 7 of 9
springDist = Measure.MinimumDistance("Work Plane1", "Work Plane2")
Parameter("21-014:1", "d3") = springDist
iLogicVb.UpdateWhenDone = True
This is all the rule does.  Just gets the distance between the two faces and then sets the spring to that distance.
Message 8 of 9
philip1009
Use the same solution that I suggested in this post: https://forums.autodesk.com/t5/inventor-forum/run-ilogic-when-part-is-updated/m-p/8871863#M750186
Basically make a sketch and put in a reference dimension between projected lines, this will cause the Model Parameter change to trigger.
Message 9 of 9
Ok thank you, that works.
