I'm running Inventor 2018 Pro on Windows 10, I recently lost Branch Components (ThreadOlets, SockOLets) from the out of the box Read Only content center. They are in my older assemblies. Any ideas?
Kevin
@Anonymous
When you say its in your older assemblies.. The content center part is or that you are seeing them in content center under tube & pipe?
Mark Lancaster
& Autodesk Services MarketPlace Provider
The part is available in older assemblies. Ex: I'm **** on it, hit place and I'm able to place it that way. It is still not available in the content center.
@Anonymous
Are those components the only component that's missing in content center? Is it based on a certain specification, ANSI, ISO, DIN? Do you have filters running in content center? IF you go to your active project file, select the lower right hand corner icon (manage content center), is there any libraries un-checked or in red?
Mark Lancaster
As far as I can tell, those are the only parts missing. I check all my filters, content center configuration is as it should be. The parts missing are Thread O Lets and Sock O Lets from the Routing CC under Branches.
