route contains invalid angles
see screenshot. all i did was moved the run over a half inch and it just cannot rebuild it. nothing at all changed except the angled section should be slightly shorter and the vertical section slightly longer after having moved everything over the half inch. as you can see the angles are nothing weird. should be a 45 and a 90 like it was just a few minutes ago. why would it say it cant build a run of 3 straight sections of pipe with a 45 and a 90? anything i do seems to have an issue in this tube and pipe. im gettin ready to just model my piping im getting so frustrated.
also how in the world do you constrain the routes? sometimes it will let me and other times it wont. like lets say i have 2 different areas that are nothing more than a pipe up 90 and then another straight section. i will have 1 i can constrain fine and then do the same constraints to the other (like included work axis and using parallel constraint) and it just wont do it says cannot create this constraint, no explanation as to why (which my goodness am i over that stuff, dont give me an error and just say cant do it, say whats wrong...like in my screenshot here it says route contains invalid angles...ok which ones would those be???? if it can recognize something is off why cant it just say what is off? i dont get it)
