Round up function not working
bwang-tecoustics
bwang-tecoustics
My inventor round, floor or ceiling function not working in Parameter tables. Do you guys have this issue? I recently upgraded to 2016 R3.
I'm assuming that you've used these functions in previous versions so I'm sorry if these questions come off as trivial but the first thing that comes to mind is: do you have all your unit types in order?
ceil(), floor() and round() only work on unitless values. If this is overlooked, the equation will not parse.
So in other words:
salariua
Units are evaluated before mean value of the parameter so you need to get rid of the units by dividing with “1mm” , process the formula and then multiply by “1mm” like this:
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
